Old 22-May-2021, 10:58 PM   #6
deeciple
Originally Posted by OTAFAN View Post
...the RCA751 you're using is a solid work horse that I've used here at my location, with excellent results in the past. But if you want to try the GE out, rabbit73 sure likes his and you can take that to the bank.
The odd situation that you describe is sometimes due to preamplifier overload. Try removing the amplifier (don't just unplug it) and run the test again.
Hi OTAFAN and Tower Guy,
I tested out the GE Pro but it wasn't any improvement over the RCA (no worse either). I did manage to relocate the RCA in my attic to somewhere without any forward obstructions. I also added a 6db attenuator. It was a bit difficult to install it in the new spot but it did improve the stability of my signal quality. I am now dropout free and the "backwards pickup pattern" corrected itself as well.
Thanks for the great advice!
Ken
deeciple is offline   Reply With Quote
