TV Antennas and Reception
The Tv transmissions are so strong that the amplifier is likely overloading causing problems , I recommend remove it. The ANT751 is a simple VHF/UHF local reception antenna it will have the same Low gain figures as a Winegard HD7000R and other antennas of this size and shape. You can get antennas like these at Lowes , radio shack and etc.. You can ask about returning it if does not improve reception. . If you think a longer antenna will fit in the attic then I recommend a Winegard HD7082P. . And again there is no reason to have a amplifier , the Tv transmissions to the east are S-T-R-O-N-G.
