Old 4-May-2021, 7:09 PM   #13
deeciple
What device is giving you those percentage readings of signal strength and signal quality?
I have the antenna/amp connected to an HD Homerun.
Is it worse on windy days?
Now that you mention it, we did have some storms pass through the area earlier in the day yesterday. It may still have been a bit windier than usual when I tested in the evening.
Your new preamp has about 12 dB more gain than the RCA amp.
Thanks, I will have to observe and test over the next few days. Do you happen to know the signal/noise ratio on the RCA? I searched but didn't find anything.
deeciple is offline   Reply With Quote
