Old 4-May-2021, 6:44 PM   #10
Originally Posted by deeciple View Post
That black thing is a duct. Not sure if it has foil inside or not. Unfortunately I am limited where I can put the antenna as the attic has very few floorboards so I have to balance on the joists. I tried to get as close to the wall as possible and low enough to take advantage of the wider portion of the wall.
I used to put sheets of plywood down in the attic so I wouldn't fall through.
