Old 3-May-2021, 6:36 PM   #8
Originally Posted by deeciple View Post
I tried to get as close to the wall as possible and low enough to take advantage of the wider portion of the wall.
I am getting about 35 channels now (all the networks plus some others). They are all coming in at about 70 to 85% signal level with the amp and about 50 - 65% signal quality.
Thank you for the signal report. It gives me a better idea about how the signals arrive at your antenna in the NW end of the attic.
Only the ABC affiliate is coming in poorly. The quality is at about 45% to 50% and it's very spotty reception.
That is to be expected. WSOC is coming from a different direction (the North) and there are many trees in the signal path that weaken the signal and reduce its signal quality.
