Old 1-May-2021, 6:47 PM   #5
deeciple
Hi rabbit73,
I got the antenna installed in the attic today. I did take a hit on signal level so I added an amplifier that I had from an RCA DN010165 indoor antenna. think it may be introducing noise as the signal quality is not better but the signal level does improve some.
Do you think a better amp would improve signal level and quality? If so, can you recommend some good low noise amplifiers that I could use in this case?
Thanks,
Ken
deeciple is offline   Reply With Quote
