Old 30-Apr-2021, 1:06 AM   #4
Originally Posted by deeciple View Post
here is a link to my signal report:
http://www.tvfool.com/?option=com_wr...9038763bf86c44
That wall faces northwest. I almost think the builders planned for an attic antenna
Thanks for the report. TVFool is using an old database to generate reports, so I did an estimated report for your location using rabbitears.info:
https://www.rabbitears.info/searchma...tudy_id=253085
You can do a more accurate report for your location at this site (I use coordinates from Google maps):
You have a few signals that should be OK with an attic antenna but they are not all in exactly the same direction.
