Old 28-Apr-2021, 10:01 PM   #2
Originally Posted by deeciple View Post
Hi all,
My question is, is that wall being free of the radient barrier enough to expect good results for an attic install?
Thanks,
Ken
Hello, Ken.
It is fortunate that there is no radiant barrier in the signal path, but there will still be some signal attenuation from the building construction.
Without a signal report from you for your location, you will have to make some tests to see if you need a preamp.
