Im putting up an RCA antenna, ant3037E 66" boom length. It's made for Hi-VHF and UHF which are in my area. There is a Lo-vhf kit included that you can add to the antenna during assembly but I won't adding that since my area has no channels below 7 in use.
The mast is 1-1/4 inch mast in 5foot sections. It will likely be about 8-9:feet above the roof. The top bracket of the monnt will be at the top of the wall below the eve. Going to install the lower one 4or 5feet down
The wall is wood not sure of how thick it's an old house that's built sturdy.
Will be aiming at the TV towers in Harrisburg PA 26 miles away from york pa
