Can the antenna operate in either the active (0n) or passive (Off) modes through the supplied amp?
JoeAZ, you probably are using the amp on in your location, but for those of us in stronger signal locations, would this antenna perform just as well in passive mode?
Thanks for the Televes recommendation and advice! All the best.....
