When you are ready to try for the Buffalo stations the 91XG will be the best antenna for you. It has sufficient rejection off the back to reduce the signal of channel 35 from Hamilton by about 28 dB and also has a broad enough pattern toward Buffalo to pick up Grand Island and the harder to receive stations on channels 33, 34, and 36 from Colden/Boston simultaneously. When aiming the 91XG, tune in either WIVB or WKBW and tweak the antenna direction for the best signal quality on your TV set.
