Tower Guy
Thanks for the feedback. The two separate antennas are what I am leaning towards but need a little bit of clarification on the external tuner. Are you referring to a signal combiner up in the attic as I would like to use only one signal cable down to the TV?
Can you make a recommendation on which reasonably priced antennas I should be shopping for?
I have read where the cables from each antenna need to be the exact same length and type and the antennas should be around 2-4 feet apart. Am I correct?
Thanks
