Help picking a attic antenna for Grimsby ON
Being new to this and living in Grimsby Ontario I am going to assume a two-panel antenna would be best, given Toronto is at 15 degrees and Buffalo is at 111 degrees (if I read the map right) with a distance of 35 miles for both. The attic is huge and easy to navigate so size does not matter. Any recommendations on a reasonably priced antenna that would work in my situation would be appreciated. Thanks
