Old 13-Feb-2021, 7:07 PM   #8
JoeAZ
Hi Set,
Yes, the antenna is exceptionally well built AND it performs exceptionally as well.
I have the DAT Boss Mix LR and found it to be incredible in every way. I watch
1 Kw translators (LOS) at 67 miles with nary a pixel or breakup. The old design
Channel Master and Winegards are good but this is sooooo very much better and
less expensive as well. The LR version, that I have, is more directional than you
need or want. I'd stick with the model I recommended.... I doubt your old
antenna is at fault with Rf 16. Be sure to avoid nearby trees in the direction(s)
you aim the antenna. Good Luck!!!!
