Old 13-Feb-2021, 1:48 PM   #6
JoeAZ
Set,
Unless you regularly watch religious programming, there is no need for a
rotor nor a bi-directional antenna. I would recommend the antenna below,
aimed somewhere between 60-70 degrees. It comes with a built in self
adjusting preamp. Let's not make this harder or more expensive than it
needs to be.....
At LOWES Home Improvement.
Televes DAT BOSS Mix Antenna Yagi Directional Outdoor HD; UHF; VHF TV Antenna
Item #2543142Model #149483
