Old 10-Feb-2021, 4:39 PM   #21
videobruce
rabbit73;
To answer your questions;
Siglent SSA 3032X
'True' north (it's easier, the house is N-S, E-W within 1 degree which makes the job very easy ).
The reference to 355 degrees is due to the offset from 330 degrees necessary being the only way I can receive the Toronto stations (RF 17-20) due to the 'swamping' effect from RF 16 even with the additional 20db attenuation from my traps. Doing so drops the offending station level over 10db making the difference.
At the present time, are you able to receive 17 that is adjacent a much stronger 16? That would seem impossible for a TV tuner to handle.
Yes it will be, especially with a crappy tuner; aka TiVo.
Is there a filter design that would work better?
I was originally going to go with Tin Lee, but due to poor communication (on their part) and cost, I went with PAR Electronics which I've done business before. I use to do business with C & E in East Syracuse NY (which were partners with Tin Lee), but they went out of business unfortunately.
See the attachment. Tuned for 15/16 and 31/32
Keep OTA television alive. Streaming is 'all wet'..........
videobruce is offline   Reply With Quote
