Old 15-Feb-2011, 7:16 PM   #5
carbon rod
Do you want WMVS?
If yes, you need large 7-69 antenna such as the HD-7696P
If no, a four bay UHF is big enough. (4221, DB-4, U-4000, HD 4400 etc)
Either antenna should be mounted on the roof and would need an amplifier such as the HDP-269.
WMVS would be nice, but is not a dealbreaker since the main channel is rebroadcast on WMTV up in the UHF range (I think i got that right).
However, I live in a townhouse and will need to put the antenna in the attic - I know that adds an element of randomness to the "will it work" question - so in this case would I be better off going with the larger antenna, assuming I could get it up into the attic?
Thanks for your help.
carbon rod is offline   Reply With Quote
