Then to sum it up you are 40 & 50 miles from any of the xmitters with high gain antennas with no real overload conditions. Is that correct?
If so, then the Avant-X would be able to handle that. How about what the spectrum looks like directly off the antennas? Also, how about narrowing up the spectrum for 'groups' of channels?
Separate question, can you confirm a software glitch where the 11th channel position on each page (the one furthest to the right) can NOT be manually adjusted + - 3db?
Keep OTA television alive. Streaming is 'all wet'..........
Reason: minor typos
