If I lived there I’d try for some of the Springfield stations. 19 & 22 look the most promising and would grab three major networks on two stations.
I feel that the best antenna for those channels is the DB-8e. He will also need a preamp. (The Channel Master CM-7778HD would be my choice because it has separate VHF and UHF inputs).
I’d try it first without the 50’ tower. Pick a location with no trees in front of the antenna and see what you get. Try several heights to see if you can find a hot spot without a tower.
KOLR on channel 10 would need a dedicated Stellar VHF antenna; perhaps two of them stacked!
