Old 25-Nov-2020, 6:07 PM   #79
That would be good if was practical. For accuracy, the two antennas would need to be located at the same physical place. In many cases at UHF, a separation of a foot or so, and the two antenna combos can receive different signals.
That is true because the wavefront is non-uniform. I have seen a difference in the scan of a channel when moving the antenna a foot horizontally.
But then, how is it possible for you to make a valid comparison of the performance of the two systems? Have the two antennas on a sliding carriage that moves each antenna into the same location, or what? Otherwise, how can you possibly get a comparison like you would on a lab grade antenna range? On a range, you would use a constant strength test signal and place each antenna, in turn, in the same location.
The closest I got to the ideal was to switch the two antenna locations, but I really wanted to be able to slide them sideways.
The white wall was just a background for the photo. The actual comparison was done at a location with OTA signals that were as constant as I could find. I used an A/B switch for a rapid comparison.
