Old 15-Feb-2011, 4:22 PM   #3
carbon rod
Don't try to combine them. Use an A/B switch to switch between them, or get an external tuner/DVR for the second antenna. For instance, if you had a Channel Master CM-7000PAL connected in your preferred direction you could DVR those stations and watch the other city live.
A two tuner HD Homerun can also deal with two antennas.
Thanks for the response. It looks like the DVR setup I'm currently using is similar in functionality to the CM-7000.
Does anyone have any suggestions on what type of antenna & if I'd need/want an amplifier to pick up the stations on my report (in the first post) starting with WITI and working downwards to WVCY or so? I'm colorblind and can't really tell what background colors are on the report.
Maybe a better way to put it is I can already get everything that's situated in the 149 degree range (down to WWME) on the azimuth column; I'd like to add the stations in the 7 degree range but am not sure what would be the best way to do so. The current antenna I have does not consistently pick up the stations in that cluster even if I turn it that direction.
carbon rod is offline   Reply With Quote
