Old 15-Feb-2011, 5:00 AM   #3
ioky
Originally Posted by John Candle View Post
I like the fractal antenna on the cork board-modern art. Each digital channel can transmit sub channels of what is commonly known as 'Tv channels' , usulay 1 to 4. Audio only channels can also be transmitted and also data. Modern Tv's are really computers , that display what is commonly known as Tv channels. . The reason the 'Tv channels' can be received with the matching transformer only is because the transmission are VERY Strong. Here is inflammation about aiming Tv antennas , yours is aimed like a flat panel UHF antenna , one of the flat sides directed at the Tv station , http://www.kyes.com/antenna/pointing/pointing.html , the circuit boards and metal objects that are placed in between the metal elements of the antenna interfer with the fractal tuning of the antenna. Here is information about Real Digital Tv Channels , Virtual Digital Tv Channels , Analog Tv Channels , http://forum.tvfool.com/showthread.php?t=695
Thank you John, This clarify a lot of problems that doesn't seem making any sense to me at all. If I am not mistaking, That means, I am not really getting any VHF. (any idea on how can I make an antenna that get VHF?)
I will eventually make the "back bone" of the antenna, instead of just pin them on the board. I making thinking to test few other shape before I finalize which one I am going to use. so I am also wondering, if I put to panel antenna "back to back" and with a reflector in between. Will I get better single more direction? or it will make thinks worse?
ioky is offline   Reply With Quote
