Old 11-Oct-2020, 10:57 PM   #1
jamesm113
Loose coax connector
Would a loose coax connector cause reception issues?
I'm trying to get two weak local stations (within 3 miles). They show up when I do a scan with an RTL-SDR scanner, but my tuner cannot get a quality signal.
Was monkeying around in the attic and I noticed the coax connector is quite loose and can even fall off the coax cable. I simply pushed it back on and everything else seems OK, but thought I should double check.
jamesm113 is offline   Reply With Quote
