Finally got a chance to get back to this
I only messed with the DB8E, so far.
Did a continuity test on all the cables and all read "Open"
Broke all outside connections and applied dielectric grease.
Found one connection was a little loose.
Checked all connections for tightness.
Had a Mediasonic tuner to see if that might help.
Didn't, so I removed it and am sending back.
Was able to get WTAE RF 27 Virtual 4 badly pixelated.
I haven't had any luck getting WWCP 8 even though I moved the CM for that.
Both my preamps are in the basement.
Could they be bad?
The splitter amplifier is brand new
Any suggestions are appreciated
Thanks for your patience
