Old 6-Oct-2020, 1:57 PM   #14
jrgagne99
Many folks will recommend that you 'walk your roof' and see if you can find a sweet spot for your antenna.
That is also a good idea, but the problem with finding a "sweet spot" in this case is that due to the close proximity to the trees especially near the chimney, the location of the sweet spot is likely to change as the trees grow. Finding a sweet spot on the southern end of the house, 50-60 feet away from the trees should mitigate against that effect somewhat.
