Old 4-Oct-2020, 3:06 AM   #7
Tim
Originally Posted by EricTV View Post
Thank you both. I probably can live without channel 2.
I did a quick photoshop to see what the 751 would look like mounted at the highest point (chimney) either with the supplied mast or with a taller mast. No mast will be tall enough to get above the tree line.
Do have a spot anywhere on your house where the antenna can get a clear shot without looking directly into the trees? Trees with leaves, especially wet leaves, are really troublesome for UHF.
