Old 2-Oct-2020, 9:47 PM   #2
Take a look at your Rabbitears report
https://www.rabbitears.info/searchma...tudy_id=158020
WGBH is now on VHF low band. You need a large VHF low antenna properly aimed at about 40 degrees. A Winegard HD8220u or ChannelMaster 3020
WNAC and WPRI are on VHF high band. A smallish antenna designed for VHF high should work OK, (ANT751 or similar) but they are not in the same direction as WGBH.
The remaining stations are on UHF. You need a fair amount of gain to get some of the Boston stations, and they are 30 degrees off axis from Providence. To get both on a single antenna you should consider a 4 bay bow-tie style antenna Stellar labs 30-2426 or similar aimed slightly favoring Boston.
Couple the two VHF antennas together with a HLSJ and then add the UHF with a UVSJ splitter joiner.
