Old 27-Sep-2020, 12:51 AM   #144
Originally Posted by blackstone View Post
Also, since the Channel Master is both VHF and UHF, could it pick up some UHF stations?
The CM 5020 antenna will pick up UHF channels, but if you are combining your CM antenna with your UHF antenna using a UVSJ, the UVSJ will block any UHF channels coming from the CM antenna.
