Old 24-Sep-2020, 10:36 PM   #131
Tim
Originally Posted by blackstone View Post
I have lost stations recently, both UHF and VHF.
Actually, I can't get any VHF stations at all.
Blackstone,
The signal reports at TV Fool are very much out of date. It would be very helpful if you could post a link to your RabbitEars report. You can generate one at this link: https://www.rabbitears.info/searchmap.php
Tell us a bit more about your antenna system.
Are you combining the two antennas with a UVSJ combiner before the preamp?
Which Antennas Direct preamp? The Juice or the PA18?
Are you using a rotator?
If fixed, which way is each antenna pointing?
What stations are you receiving with good results?
How are your connections waterproofed at the antenna and preamp?
