Old 13-Sep-2020, 6:51 PM   #51
Using an Attenuator to Measure the Strength of a Digital TV Signal
Here is an example of using an attenuator to measure the strength of a digital TV signal. I picked RF channel 20 to measure.
This is my signal report in dBm:
https://www.rabbitears.info/searchma...145947&opkey=C
This was my setup:
Code:
                                  TV for SNR
                 0 to 10 dB          /
Ant > 25ft RG6 > Attenuator > A/B Switch
                  at 0 dB            \
                                  Meter or SDR
The Sadelco DisplayMax 800 signal level meter reading was -7.3 dBmV = -56.1 dBm
I added attenuation, for a total of 30 dB, to bring the signal down to 15 dB SNR at the "Digital Cliff."
Code:
                                                TV for SNR
                 0 to 10 dB      Fixed             /
Ant > 25ft RG6 > Attenuator > Attenuators > A/B Switch
                  at 7 dB        20+3 dB           \
                                                Meter or SDR
This is what the scan looked like at dropout. Note that I had to increase the SDR gain for the proper display:
So, to calculate the signal strength, the basic rule says to add the amount of attenuation needed for dropout to -85 dBm, which is the average dropout point of a tuner:
-85 dBm + 30 dB = -55 dBm
The signal level meter reading for the signal was -56.1 dBm; close enough for a good estimate to determine the signal strength.
The 30 dB of attenuation needed to bring the signal down to 15 dB SNR is sometimes called Margin to Dropout.
Channel 20 is listed at -26 dBm on my report. The trees are causing a lot of signal loss.
Note that I really only needed the TV and the attenuator to determine the signal strength. I added the SDR and the signal level meter to verify the method.
