Old 3-Sep-2020, 3:49 AM   #20
Originally Posted by verder
You mentioned: "The only other possibility I can think of is an antenna with a wider beamwidth." Is there anything available that is at least 180deg bidirectional that has a wider beam width? Is the ClearStream 4Max as good as I'm going to get, or are there alternatives?
I had thought that a Antennas Direct DB4e with the reflector removed might be worth a test. You would have to add a dipole for VHF channel 13.
I will try to find some antenna patterns; they are getting hard to find.
