Old 3-Sep-2020, 3:43 AM   #19
Originally Posted by verder
Here's the SpectrumSpy trace from my antenna:
https://imgur.com/a/XMGGyx7
Thank you for the UHF scan; nicely done.
KVRR virtual 15-1 RF 19 shows a little more than the minimum SNR for reception, but could be a problem at times
WDAY virtual 6-1 RF 21 is your strongest channel; shouldn't be a problem
KRDK virtual 4-1 RF 24 is a little stronger than KVRR; could be a problem at times
K28MA virtual 28-1 RF 28 is very weak; doesn't look strong enough for tuner lock in this scan
KXJB virtual 30-1 RF 30 is fairly strong but shows possible multipath problem. It is listed as second in strength after WDAY, but is a low power station
https://www.rabbitears.info/tvq.php?...s&facid=185885
KVLY virtual 11-1 RF 36 shows just barely enough SNR for a tuner lock and would be expected to have problems
This is my UHF; CH 14 doesn't decode. I like to show the settings and have added arbitrary numbers to the gain scale. I bring the gain up until the noise floor just starts to rise and stop, which should show the correct SNR.
The weak signals got a little better this evening:
Videos, no audio
https://www.dropbox.com/s/eusj9k25wg...08-07.mp4?dl=0
https://www.dropbox.com/s/eusj9k25wg...08-07.mp4?dl=1
Here is FM and VHF-High, no audio
CH 7 is around 175 MHz; it is damaged by multipath and doesn't decode
CH 11 is around 200 MHz and usually does OK; the noise level is high
https://www.dropbox.com/s/fnjyuttou2...54-35.mp4?dl=0
https://www.dropbox.com/s/fnjyuttou2...54-35.mp4?dl=1
