Old 2-Sep-2020, 2:24 AM   #16
Originally Posted by eclipsme View Post
RTLSDR Scanner is available as executable install. Hopefully making this part much easier:
https://github.com/EarToEarOak/RTLSDR-Scanner/releases
Your video quite nicely shows the affect of the gain control. I look forward to playing with this.
I have the dongle on order, along with an adapter. Should be here tomorrow...
I'm glad the video helped you; it is an important concept when using the dongle with SDR#.
Adjusting the gain of the RTLSDR Scanner is a little different. You raise the gain until the noise floor starts to rise and then stop. More precisely, when it starts to rise you back it off a little.
Gain set too low:
Correct gain setting:
Gain set too high:
With the RSP1A and Airspy R2 you adjust the gain and other contols for max SNR.
Good luck with your adventure.
