Old 31-Aug-2020, 11:34 PM   #5
Originally Posted by verder
Thanks for posting that info. Yes, you can show that picture in the thread.
OK, thanks
How did you get those tower line of site overlays into that picture? That's very cool!
I used the TVFool Interactive Browser:
https://www.tvfool.com/?option=com_wrapper&Itemid=90
The green signal lines are based on old channel data, but it gives the general idea.
Channels checked:
4-1 (KRDK) COZI, Real channel 24, 324.8 deg True, Signal Margin 39 dB
6-1 (WDAY) ABC, Real channel 21, 306.1 deg True, Signal Margin 68 dB
11-1 (KVLY) NBC/CBS, Real channel 36, 331.6 deg True, Signal Margin 53 dB
13-1 (KFME) PBS, Real channel 13, 307.5 deg True, Signal Margin 59 dB
15-1 (KVRR) Fox, Real channel 19, 111.7 deg True, Signal Margin 56 dB
28-1 (K28MA) CBS/CW, Real channel 28, 331.6 deg True, Signal Margin 40 dB
30-1 (KXJB) CBS/CW, Real channel 30, 101.7 deg True, Signal Margin 60 dB
I now have the antenna connected to a Tablo Quad (4-tuner) DVR. The problem I'm having right now is that I occasionally get dropped recordings for
channels
4-1
11-1
15-1
28-1
It doesn't happen all the time. I'm questioning if it is the Tablo or the antenna.
I have no experience with the Tablo. How do the problem channels do with a TV tuner?
I've heard that the Clearstream 4Max has a narrow signal reception angle, and I'm wondering if a cheaper RCA ANT751E from Menard's would be a better option:
https://www.menards.com/main/electri...4940301502.htm
That version of the 751 has fewer elements than the original 751.
I'm sure it doesn't help that I have towers almost 180 degrees apart. I need to receive both from the northwest and the southeast.
The CS MAX4 does have a narrow beamwidth, but since it doesn't have a reflector, it is bi-directional.
