Old 31-Aug-2020, 6:22 PM   #1
OTA recommendations
By PM:
Originally Posted by verder
I've seen your posts on here that are extremely informative. That lead me to register here, looking for advice as a recent cord-cutter. Problem is, my account hasn't been approved yet so I don't have permission to post. Would you be ok if I sent you a PM with my details and you could re-post that for me on the "Help with Reception" subforum?
Thanks.
Hello, verder.
Many others have to wait because the TVFool staff is very small. Some never are able to post. This forum is becoming less active; it isn't as secure since they didn't renew their certificate. There is no longer https:// in the address.
If you get tired of waiting, you can join the AVS Forum:
https://www.avsforum.com/forums/hdtv-technical.25/
I will try to help you with your OTA problem under these difficult circumstances.
I will need certain information, like a signal report, a description of your present equipment, and what channels you hope to receive.
If you are willing to give me your address and coordinates of your antenna, I can get a signal report from rabbitears.info and look at your location in a satellite view.
The signal reports from TVFool now contain errors because they are using an old database to generate reports.
https://www.tvfool.com/index.php?opt...pper&Itemid=29
If this conversation continues, you should know that you are presently limited to 5 PM messages. If you don't delete the earlier PMs, I will get the message that your inbox is full.
rabbit
