I appreciate all of your feedback. Yes, I can see that my local CBS affiliate WFMY on RF51 would deffinitely be a factor here. This channel shows 56.5 NM (DB) on my tvfool report. So obviously, it is a much stronger signal at 30 miles away to the SE versus the main signal for WAXN which is over 60 miles away to the S-SW. Topping that off, since my report shows I've only got 4.9 NM(db) to work with on the main signal for WAXN (in the first place), it makes things bad all the way around.
As Tower Guy posted, I guess WFMY RF51 could be attenuated. (I am not sure how that works but could find out).
