Old 29-Aug-2020, 4:50 PM   #2
Sev
The following are 4 data sets. Sequence matches the traces.
Keep in mind. Each one is a snap shot and time and they actually fluctuate on the spectrometer
DAT
8800
DAT
4228
This second set has each D3 reading with the arranged with the specific antenna the DAT was going against at the time.
DAT-8800
DAT-4228
Conclusion.
The DAT shows itself to be pretty solid against the 4228 and 8800.
It distinctly came out in front on RF9
On RF14 if you look at the traces closely it came out slightly ahead of both the 4228 and 8800
RF35 it was distinctly ahead of the 8800 and edged out the 4228.
On RF's 16 and 32 the DAT is was within a couple dB of the both the 4228 and 8800 on the D3 readings. On the traces all 3 antennas are pinned as high as the readings will allow. Basically showing a tie.
Sev is offline   Reply With Quote
