Old 28-Aug-2020, 2:53 PM   #4
alphonsobellinni
Using a test procedure from Channelmaster support, I figured out the problem: dodgy coax from power supply to preamp. More than likely an open in the shield, as you mentioned.
Wiggled and jiggled cable and it is working normally at the moment. Replacing cable this weekend.
Thank you for the response and suggestions.
alphonsobellinni is offline   Reply With Quote
