Old 14-Feb-2011, 9:03 PM   #1
ioky
What is really getting the signal, and How can I improve my setup
Hi Everyone, I am new to this forum. So if did something silly please let me know. and Thanks for the great website
I am current experimenting with this "Antenna Stuff". (Seem pretty cool to me)
So without too much of background knowledges. There are few things that kind of corners me a bit.
So Here is my antenna and TV: Dynex DX-15L150A11
As you can see it is a bit "funny" looking. I modify from the well known Gray Hoverman antenna, with some fractal elements (Yes, I know it is side way. I did that just so it fit on my board the way it is. I did test it vertically though.) As you can see it is an in-door antenna. And I am not yet interested to do exterior antenna testing for now. (well... It is winter...) Just want to focus on in-door antenna for now.
The antenna is connected to a 300ohm to 75ohm transformer. Here is the funny thing. Even without the "antenna" the Transformer alone is able detect all 19 channels I get with my antenna attach, the only difference is, I get much stronger signal with the antenna. (this makes me wonder how much better I am actually getting with this antenna.)
The other funny is neither with or without the antenna, I am not able to get any analog Channels, for my local area, which for fact, I know there is still at least one very locate station that is broadcasting with analog signal. (Well my other TV with a built in antenna is getting that, so I know for sure.) So I just wonder is it hard to get analog then digital signal?
I do want to get these analog channel though.
NOTE: I also did tested an antenna I get from store, hoping I can get some analog channel (it did not)... I get all the channels I get with mine (no more, no less). But the signal is not as good. so... I return it.
In term of Channel I am getting. Here is my report for TVFool
http://www.tvfool.com/?option=com_wr...e07c64b981129d
base on the image I show. The antenna is "facing" North-ish eastern... (Not totally sure.)
I am getting almost everything in Green. expect for channel 62.1 (Ind) and 48.1 (Ind). I do wonder why I am not getting all these (Ind) channel. and I can get Channel 66.1 depend on where I put my Antenna which is 25.5mile away. So I guess this is pretty good. (for the very first antenna I ever made.) for Channel 38.1, I can ever get a really strong signal for some reason, it is good enough... but not the best, it is like 3/4 (base on the scale my TV show... kind of like the one way I can measure the strength of the signal anyway. )
I don't know. So I am wondering is there anyway I can improve signal gain. My goal is to get MynetworkTV or at least getting some "yellow" channel on the report. So I guess to find a way to increase NM(dB) is the key?
http://www.tvfool.com/?option=com_wr...ALLTV%26n%3d27
This one, but again, I don't know if this possible. (with an in-door antenna)
Here is few general Question I would like to ask:
is there any better way to get Path: "edge diffracted" signal?
is adding a reflector a good idea? in case of when?
Should I add an amplifier? and what kind of amplifier I should Get? if Possible How to make one.
Thanks for your time, and help.
ioky is offline   Reply With Quote
