rabbit73,
Thanks for the reply. When you get one of those round toits, I'd also be interested in your thoughts on the related questions:
When you say, "The SNR is measured from the noise level to the top of the signal." do you mean from 0, or from the top of the noise level?
I'd hate to replace the antenna, but would consider doing so if there were one with a better VHF section. Can you suggest one?
Keep in mind that I removed the UHF section and attached the balun directly to the end of the connectors that reached from the VHF section thru the UHF section. Might a gain of even 2 or 3dB on Channel 2 be significant?
Regards
