Old 13-Aug-2020, 10:33 PM   #19
Sev
Coming from someone called "SEV" has me rolling with laughter!!!!!!
In major cities perhaps. That does not make them blowtorches.
I'm in the Appalachian mountains. So once again you are attempting to compare apples to oranges.
It could be a translator. However.
Both RF35 and RF5 are on the same tower at 2438' transmitting at 29.9 kW's and in 1080i and DD 5.1.
Perhaps you would like to point out specifically where I stated that the DAT would perform the same or similarly as a dissimilar antenna designed to include the VHF LO portion of the spectrum.
You do realize that the broadcast spectrum now only extends to the RF 36? Yes?
Anything beyond that is now legacy.
All antennas are now limited to a small portion of the broad cast spectrum due to the repack.
So again. You point is neither accurate and is irrelevant.
And now that it appears that you have sunk to the level of engaging in personal attacks.
I accept your surrender.
Please seek help for your TDS (Televes Derangement Syndrome).
Thank you for playing.
Sev is offline   Reply With Quote
