Old 29-Jul-2020, 7:10 PM   #5
Tower Guy
Your plan to add MOCA to your existing set-up is a good idea. The MOCA distribution amp that you found would work fine, or you could simply add a MOCA filter between the distribution amplifier and your existing splitters. The splitters for MOCA need to be able to pass higher than the usual off-air frequencies.
A problem with WiFi extenders is that they use up bandwidth to send data between them. If you use MOCA to extend your WiFi, you get that bandwidth back.
Another trick you probably already know is to move your WiFi channels off of the factory settings. This may get you a frequency that your neighbors are not using.
