Old 8-Jul-2020, 2:44 PM   #3
jrgagne99
I had a similar case a few years back. Memory on it is a little bit fuzzy, but I believe my Sony's channel list under this scenario included duplicates of the virtual channels. So when you flipped through the channels, the first 28.1 that you came to was on one RF signal and then the next channel up (also a 28.1) was from a different RF signal.
I got a similar behavior last weekend when I had to do a re-scan due to the FCC repack. I had duplicate virtual channels in the channel list, but one of them was reading "no signal" because the station is no longer broadcasting on the RF signal that that virtual channel is associated with.
Does that make sense?
