Old 28-Jun-2020, 7:44 PM   #19
Tim
Originally Posted by derf View Post
Another question.
Based on the RabbitEars graph, should I consider removing the reflector on my antenna? Channel 30 is the channel we watch most and it's about 180 degrees from everything else.
Are you having trouble with receiving that channel? If not, I wouldn't touch a thing, but if you are having problems you can certainly give it a try. You can always put it back on if it doesn't help.
Just note that channel 30 is so close to you and so strong, if you are having receiving problems there is a slight possibly it could be signal overload due to your amp. Have you tried that station with and without the amp to see what the difference might be?
