Old 26-Jun-2020, 11:47 PM   #14
Tim
If the cause is a too strong signal, you could try just a splitter instead of the amplifier you are using. Your local home improvement big box store should have a splitter in stock. You possibly could try it and if it doesn't work return it. Over amplification of strong signals can cause reception problems. But I would try installing the VHF element first before going down that route.
