Old 14-Feb-2011, 7:07 PM   #1
saintbaud
Need advice on antenna for OTA TV Stations
See my TVFool below:
http://www.tvfool.com/?option=com_wr...e07cf7ecb50a98
I have a HD TV set and an older standard Def set. I am looking for a good antenna for High def channels in NY area (and Philly stations if possible). I need to know the following:
1. Type of antennas: Model Number of Roof mounted, attic antenna,
or others. Do I need VHF or UHF antenna?
2. Do I need a pre-amp, a rotor, etc.?
3. Can I split the signal between two TD sets: one HD and one standard
Def?
your advice is appreciated.
saintbaud is offline   Reply With Quote
