Thread: Signal analysis
Old 14-Feb-2011, 11:29 AM   #7
No static at all
No static at all's Avatar
Originally Posted by scott784 View Post
But again, when a tvfool report shows a station at 5NM(db), is it normally a lost cause in terms of trying to grab the station?
A noise margin of 5db is doable in some cases, but it is so close to the digital cliff, reliability is unpredictable. As John pointed out, you have an adjacent channel issue with a much stronger RF 51 in the same direction which isn't helping either. I personally find about a 1-3 db noise margin as the drop off point for an un-amplified 91XG.
