Old 12-May-2020, 5:55 PM   #10
bobsgarage
Antenna Enthusiast
bobsgarage's Avatar
See post #2, I described where I drill them. A hole in each of the corners of the bottom of the housing that are closest to the F-connector. Do not drill in the corners directly under the driven element.
You can do this "in the air", if you choose, but you might get wet!
If you need a photo, let me know and I'll post one up here.
Seeing how we're on the subject of 91XG's, though it was a couple years ago I am experiencing an anomaly.
My original XG was on the mast for 4 years without the water relief holes drilled.
I brought it down to repair the reflector I decided to try some DXing and to pair it with another 91 XG. But first, I decided to test them separately and I'm glad I did.
At first I thought it was a ladder blocking signal under the right side so I moved them over to my other mast. Yes, there is still a ladder under the antennas. This one is much lower under the array and more equal between the two antennas.
There's quite a difference in signal strength between what should be equal signals.
