Old 24-Apr-2020, 3:17 AM   #28
Tim
Thanks Tim, I'll look at that dipole calculator.
How do I specify if I'm building an antenna for all hi VHF channels RF 7 - RF 13 ?
Again thanks for the info you just made it interesting for me!
Unfortunately you can't with that particular calculator. For channels 7 to 13 you'll need to cover a range from 174 to 216 MHz which is probably not possible with a Yagi (that I am aware of).
You might want to check out a log periodic antenna. Enter your min and max frequency and maximum boomlength into this calculator (https://www.changpuak.ch/electronics/lpda.php) and see what you come up with. You could probably get about 10 or 11 dB of gain on a 12 ft boom with about 15 elements.
