Old 23-Feb-2010, 1:00 AM   #3
kernow
thanks.
I should also mention that WUSF came in strongest about 180 degrees out from 229 degrees even without the CM7777. The problem was it was very variable, I might have a watchable signal for an hour then it would break up every few minutes.
If I am understanding correctly though you are saying that even when not tuned to a particular station the preamp is overloading and causing odd behavior?
None of my locals has the signal strength meter pegged in its current position.
I shall disconnect the preamp tomorrow and report back.
kernow is offline   Reply With Quote
